They did make the track version but decided to dis continue it as it was not cost effective as a tracked model, only the 4WD version remains. I believe there are further models in development.
Sent from my iPhone using Arbtalk mobile app
  • Replies 29
Here is a quick glimpse of the 2550xp on tracks, still 45hp turbo but an option to the 4WD version, hopefully making an appearance soon. Built on Bandits own track base.
Sent from my iPad using Arbtalk
  GlobalNewark said:
[ATTACH]159861[/ATTACH]
Did they forget they had to put the engine somewhere on that one Dean ? :001_tongue:
Hope you are ok ?
Some nice kit though
Hope you are ok ?
Hello mate, I'm down in Essex & Suffolk on Monday delivering a few new grinders if your about. All the engines are on the rear now there are no belts.
Should be about mate, give me a call when you are in the area.
That tracked 2550 looks sick. Any more idea of how it compares to the wheeled unit in regards to mobility, if it likely to cost more, and when you might have more info? :)
Hi Martin, you have seen as much as me at the moment. It will definitely be more expensive as it will be radio remote only, I don't think it will go anywhere the 4WD won't go & tracks make a lot of mess when slewing so boards would be needed. I think personally 4wd or tracks are personel preference.
  Burgess said:
I think there's still space for them to put a few more safety labels on it.
Not enough for some, I'm sure next week we will be reading again if that someone's lost bits of themselves or worse.
Read more
