  • Replies 43
Stevie, just buy a lockjack and some different length tape slings instead of all that caffuffle, crabs and hardware.
A tiny little neat package
Failing that buy one of these.
...and if that doesn't do it get a job with the council painting yellow lines :001_smile:
Thought that might tickle you :001_tongue:
I actually took that photo and it made all the nationals.
Anchored off on lower branches to get downward force on the thin branch rather than lateral force :001_smile:
Up there for thinking, down there for dancing
Edited by Dean Lofthouse
definately different dean, were you just playing or do you actually use these different methods at work?
I use that high in the canopy to get far out without lateral loading, I was playing about there though, It was only about 10ft up :001_smile:
Your actually doubling your loading at your high point. I'm not a fan of the system as you could actually induce branch faliure through it's use
were you just playing around with different ideas, or is that the way you do most of your stuff.
Totally unecesary just mucking about with some ideas. I usually just climb like most normal people, but all these ideas and little tricks are good to know and store in the old mental toolbox as occasionally maybe once a year it'll help do a job thaty little bit easier and safer.
