Service Kit for Greenmech 15-23MT34
Si Stevenson
Can anyone steer me in the right direction for a service kit (filters) for this machine?
Engine is marked as Daihatsu 950DT
Plate states:
Model 58A447
Type 0305-E2
I have checked the net, but got into a tangle of similar engines though not quite the one!
Would be helpful if someone has already been through this pain........to save me doing the same!
Thanks in advance:001_smile:
Like I said it's not something I wish to drag through a forum. Pete's a great salesman, I have had problems with the rest of the set up.
Anyway I was told to go to "Briggs". Johnny Briggs! I assume it's a Briggs Stratton Engine, but I am struggling to confirm this and find someone to supply the parts - that's not in America!
I've just done the oil filter on mine (34 hp turbo daihatsu motor) with an 'off the shelf' filter NOT of daihatsu persuasion.
I googled the code on the daihatsu filter and got loads of other manufacturers cross refs.
The filter I fitted cost a couple of quid an is Filtron OP564. (from local Camberley Autofactors). I've run the machine for about 6 hours since changing it so it seems fine.
As for other bits just get googling - I'm sure they are all out there.
Cheers Shane,
I have just contacted the "Briggs" dealer in UK.
Next move is to get dirty and try and find some part numbers on the existing filters.
Seems a bit like reinventing the wheel..........I'm sure some one could make some money supplying "service kits"!
