We moved this entire Cedar through a gate and onto the tractor forks a ring at a time, made it so easy, love it on certain jobs, would not say we use it that often, but on some jobs it is worth its weight in gold, much like the grcs
Great size rings....moved similar size Cedar rings with the A.T....this is where it comes into it's own and quite frankly a wheelbarrow can't cope...before the Arb.T came along I was involved moving similar size discs long distance on a barrow...it was almost flat by the end of the day....wheels were hanging on by a thread.....great pictures mate.
Yes we did 2 as they got smaller, but the big ones were easier if you put the a t on its end against the ring, with the frame just under either side of the ring, then pull a t down to horizontal and off you went, as you say they would kill a wheel barrow, and you have to lift them, this way there is just a bit of man handling but no lifting, happy days
  • 3 years later...
Just to follow up, they didn't have those wheels in stock. They contacted me and said they do have a foam filled, steel wheel WITH ROLLER BEARING!
Even better so went for that. I'd only seen those from the states before.
Read more
