If you're just starting out and you need business, equipment, tech or training support you're in the right place. If you've done it, made it, got a van load of oily t-shirts and have decided to give something back by sharing your knowledge or wisdom, then you're welcome too.
Question
chrisgilltreesurgery
Hi, I would like your advice please on this job.
3 pine to be removed next to a garage, the trees are significantly older than the garage. I know broadleafs should be removed over a period of years to stop heave from changes in the water table, is this the same rule for pine's and if so what would you recommend?
Thanks
Arboricultural Association Approved Contractor
13 answers to this question
Register a new accountSign in
