Am trying to set up a bay in a shed which will dry out loose split logs, they will be loose, not in bags pallets or crates, just shovelled in and out with tele handler, any suggestions welcome .
Thanks.
Just a thing that came to mind would be that though ud get the heat from the chip would you not also get the vapour from the chip into the split logs ?
Interesting idea and will follow this bud👍
Drying grain then you used to put ventilated tunnels under the crop, however logs will destroy them.
When I did them in bulk I just plonked them into one huge heap. However when you get to the bottom of the heap you get a huge amount of crap ( bark, chips etc) that have congregated there. I had to fill 15 bags by hand to separate the crap from teh decent wood.
I moved to using arb bags, stack them 3 high with the teleporter, logs dry lovelly in their own time.
A
