  • Replies 26
well that depends. a shredder blade with bent ends will mulch cut stuff.
the saw blade will cut down but not mulch.
use two types, the saw blade for cutting and the mulching blade for clean up.
Tbf just a tri-blade will destroy anything it meets on an engine that size
Sent using Arbtalk Mobile App
maybe, but once its all flat on the ground the tri blade wont mulch it up but will just run oer the top.
but the mulcher blade is 100x better
Depends, if there is a possibility of obstacles, such as fence posts, steel mesh, gates, concrete slabs, etc the tri-blade lasts much longer as you cut through it all
as sthil do there mower type blade that is what i would use. had a go on a big sthil with one and made a cracking job better than a tri blade. cuts much faster. but as for mulching unless you go in and do the bouncing down method on top instead of sideways motion. it will smash it down so you can then just go in sideways on the bottom to cut it off to ground level and it will be in bits to rot away.
