pto log splitter
bill
  • Replies 23
what are the hydraulic sockets called on a tractor? i need to find out if this tractor has the right connectors.
you can usually get adapters to make machinery work on different tractors if you have a hydraulic specialist near by they willbe able to advise
'Dowty' fittings were the older type - about 1.25 inches diameter. The appliance end has a threaded fitting with four alloy lugs on it.
The newer "quick fit" links are like a bigger version of an airline and are supposed to make life easier by just pushing together but can be an absolute pig if there is any residual pressure in either side of the hydraulics.
Either way, you can get an adapter made up for a couple of quid so it is not a show stopper whatever mix of fittings you end up with.
