Garden Hire Spares pot and piston refund
  • Replies 24
I've had that once before now.
I have in the past used a cheap pot and a meteor piston, I have had no bad results from this.
It is generally the piston side of the cheap Chinese stuff that is crap. The cylinders are not that bad. I have had one where the ports where not beveled properly so IMO would snag a ring but they where soon smoothed off.
There was a question a while ago about what cylinder to use if using a meteor piston. But I don't think it ever got answered. As just by looking at just a cylinder you can't tell if they are the cheap ones or not. They all look the same, unless its genuine from a dealer.
I always take the edge off the ports on two stroke barrels, it only takes a few minutes with a Dremel or Powerfile. I got an Indian made one for my scooter an it was a terrible finish and needed smoothing and honing.
I had a 026 pot set from them and the first clip I put in broke when I was trying to put it in so I used one of the old clips fine
3-4 tanks of fuel later went to the saw would not start so took it to bits (lucky) other Chineses pin had fell out lol
I could not be bothered with the hassel of ringing them
They would telling me I broke it its not there problem
How do u prove that it's the product not the bloke that put the saw back together
Fault
I won't buy a Chineses pot again
As said before u pay for what u get
When u look at a OEM pot u can see alot of difference from a machining point of view is miles better the pistons fit in the pot better to
Yeah I might have ago at honing the original head and get a metor piston
Don't hone the pot it's nickel plated u will only fetch the plating off (done it with a steady flex hon)
Post pic of the inside of the pot on here and flick through what's on ur bench forum. It will tell u how to deal with ur problem if ur pot ent scrap
Does that apply to the original husqvarna pot ? Seems pity not to use it as is only very lightly scored
The only ones u can really get away with it is the old pots that have a cast iron sleeve in them
If its light on the scoring
Read what's on ur bench forum and look at spudulike posts he posted once in great detail how to clean up a scored pot with out doing any damage
So u can re use it
I would find the link for u but I'm stuck up a willow waiting for my groundy to clean up lol
