Can anyone help out a complete novice when it comes to walking sticks? I have the sticks (seasoned) but only just found some with 'built in' handles so I need to know about making and attaching a handle to a basic shank... or can someone sell me one and tell me how to Tracy it!! :confused1:
Hi there, there's people on here more qualified to answer than me but i've made some walking sticks and so will add my 10p worth.
If you're taking the time to make a walking stick properly make sure its straight. you can add heat to a stick and manipulate it straight. either with a steamer or i've done it with a tea towel in the past. can take a while without some kind of jig but it is do'able.
Then you'll need need a colar which forms the link between the stick and the handle. this sits around a short threaded bar. I use M8 bar for this. Pre drill the hole or it'll split your stick.
Finish it off with a ferrule which will protect the end of your stick. You can get nice ones but i just stick rubber ones on.
Not sure if that helps and like i said some of the other fellas on here probably have much more to add than what i can.
Cheers
S
Normally they use threaded bar, drill holes in both shank and handle, glue using arildite or similar glue, file and sand to suit
as above i use araldite and a cut down 8mm bolt threaded bit only
use a ferrule on the bottom of stick it saves wear to the wood
Beaten to it
Thank you for the help folks and I think I will grab a copy of that book also! I have been looking at using a household steamer and piping to steam and straighten sticks but the handles are giving me no end of grief! It is for my Dad who is very ill so I would rather not cock it up and add a fall to his situation :blushing:
