I am about to renew the floor on my trailer, I'm not paying the £90 odd a sheet for the proper Ifor Williams stuff, so instead, doing it in GPB ply.
Anyone recommend a good preservative/treatment, I will silicone all the edges first to stop delamination.
This is the first time I have ever used it ( on my log store roof in the absence of felt ) but I am impressed how well " ducks Back " repels water . Too thick to spray on . Brushed on 3 coats and it is quite literally...... like a ducks back ....!
Put a layer of 6mm stokbord over it.
You can weld or hot-glue them together quite easily for a long lasting solution.
About £30 for an 8x4 sheet but made of recycled plastic so it'll never rot.
It's very tough stuff...
Sounds good !:001_smile:
That sounds the biz, I thought that stokboard was about £80 a sheet, where can I buy it for £30?
Try solway recycle or your local farm supply spot.
Have relined a hi lux with it, downside is that it expands a lot with the weather this summer. Perhaps fix one end and an expansion gap at the other?
Sent using Arbtalk Mobile App
So go to Indespension. I've redone a couple of trailers and found that they were much cheaper than specialist suppliers for the phenolic resin coated ply in 10 x 5 sheets and as they use it themselves there was no delivery charge to their depot local to me.
But then i decided to do my chipbox in it and had the luxury of time. If you need a few sheets then try fleabay as the haulage becomes ok. I only paid £30 for 9mm, £38.40 for 12mm and £48 for 18mm inc. VAT (8 x 4 sheets)
PHENOLIC RESIN PLY PLYWOOD 18MM TRAILER FLOOR FLOORING NON SLIP DECK DECKING | eBay
They do delivery, just call them.
Would recommend them.
Regards,
Steve.
