BIG BAR options
Big Beech
wel, time is coming soon to start on this big 4.5ft Burr oak.
trouble is, I will need a bigger bar than my titchy 47" duromatic.
as I see it, I have two options. Stihl 59" or Cannon 60" super bar or?
other than a cost difference and me getting 20% off at my local dealer on the stihl, would I see any gains on getting the cannon? my concern is flexure when set up on the mill. I don't want saggy boards :biggrin:
thoughts, hints n tips welcome.
simon
simon
I have a ...I think 50" Canon that has top go on my 3120 some times . Not for milling but for bigguns . It is very broad compared to the 42" it usually wares so I am, assuming the Canon bars would be more rigid with less flex therefore straighter boards ? possibly .... :001_smile:
simon
I have a ...I think 50" Canon that has to go on my 3120 some times . Not for milling but for bigguns . It is very broad compared to the 42" it usually wares so I am, assuming the Canon bars would be more rigid with less flex therefore straighter boards ? possibly .... :001_smile:
You'll always get some flex going longer than 50"...
I have the Stihl at the moment on the 090 and have had cannons in the past - I'd say there's not much to choose between the two...
I have the 72" granberg bars which are very thick and flair out very wide in the middle but they ain't cheap! And you need a helper handle with roller on the far end (or another saw...)
But if you wanted to go down that route I would throw in a handle with roller free with the bar.
:001_smile:
Have another go at ordering... what computer/ipad etc are you using?
Minimising bar sag - hmmm... I suppose have the saw set back a little from the mill... the weight as the powerhead sags down slightly pushes the middle of the bar up a little.
:001_smile:
