Can any one help?
Guss109
Just wondering if any one out there can help its coming up to my 5th wedding anerversy and I'm told its wood. So I'm looking for something like this in ideally burr elm
Or something similar if any one can help.
Cheers guss
Sent using Arbtalk Mobile App
Hopefully tony as I'm running out of time as I've left it to the last minute as usual. I was thinking of an axe shaft then I can get a use out of it when I get let out but think she would try it out on my head first
Hi Guss
I am in Glenrothes and have carved a few bowls in my time. I am a bit busy just now so if you aren't in too much of a hurry I could do one for you. When do you need it by.
Mike
Hi Mike
That sounds good thanks for the offer I might just take you up on that. I'm up at carrbridge at the end of the month and there is ment to be a stall there so if I've no luck I will be in touch.
Guss
