Whats the difference between the Vertex and the Alveo?
Rock Monkey
As far as I know, the Vertex has a strap cradle that is in contact with your head, the Alveo is lined with polystyrene that is in contact with your head.
Although I've never used an Alveo, I've worn an Elios (also with a poly liner) and it's a less ventilated helmet (hotter) than the Vertex I use for work.
Hopefully someone with an opinion on the Alveo will be along.
