So bored sitting at home kicking my heals due to the recent op, that in a moment of madness I decided to buy a 372 bb kit for my 365 special.
Question is im already thinking about diving in when it turns up and porting it up fairly serious before even fitting it.... :sneaky2:
  • Replies 76
Worth doing if YOU know what you are doing . easy to get it wrong though ! If you are not sure send it to spud . He did my 372 and it made no end of difference .
Go bananas:
Ive done a few in my time and ive plenty of time to spend given im not working for a while, I done a 357xp yesterday and got the tools etc. If that wasn't the case or I was busy I would send it to spud as you say.
Im certainly considering more hot than not lol.
Debating going with a stihl piston tho and windowing it etc. :sneaky2:
Nice bit of porting on Wyks pic, would stick to the standard piston, the factory squish allows the base gasket to be dropped or you can machine a pop up to increase the compression if you have or know someone with a lathe
That's a bud's porting in Australia. I've only ported one saw so much, and it was a lil saw. I like to be a bit more subtle with my work saws. Anywho - here's what that exact jug can do when you put it in a 365 chassis:
[ame=http://www.youtube.com/watch?v=AB5kx0TWzxE]372XP big bore ported 32" bar hardwood - YouTube[/ame]
That looks like 'stringy bark' - a type of eucalyptus?
I put a mildly ported BB it on top of a 365 once without raising the transfers and I got enough torque to pull a 28" bar buried in hardwoods easily. I am gonna run an 8 pin and a 20-24" bar with my most recent attempt... if I ever get that 365 chassis form England. Prolly a month or two away. Mebbe we can do a get together?
Edited by wyk
That's one of timberwolfs saws isn't it Wyk? I believe that's on a Chinese husky copy saw?
Well its turned up and within an hour I started grinding. TBH it looked a decent kit in the first place and porting etc was half decent. (its a hyway kit which has been getting good reviews)
Ive not done much with the transfer other than to add a bit of sweep towards the inlet port.
Its a bb kit spud so not the standard piston. Will check squish when I fit it although I was hoping to get a timed cut on the oe 365 and get back to the same log and do a comparison altho being a bit of a cripple in the fact I still cant stand up straight, have a numb groin still and not meant to lift more than 1 kg it may get bolted on before I get chance to do a before and after test. :001_rolleyes:
The HyWays are sposed to be a bit more aggressive than stock timing, anyways.
The vid is Al How in Australia. Ya know him as Aussie1. I think I have a HyWay here as well. Lemme get some of the stock photos of it I took before porting..sec
Look familiar? I have it mildly ported now, but was considering just going freakin nuts with it since I rarely use my own saw in work and am about to get either an Echo 500P or Husky 550(and just do a simple MM to it and use it for work).
