Advice on petrol leek please
wayne 4098
Never cared for petrol leeks myself, much prefer the electric ones.
I prefer mine in a white sauce......but back to the issue, are you sure the fuel is coming from the carb?
Leaking fuel lines/tank connector, breather/vent, tank cap etc can cause fuel leaks but if it is coming out of the carb then a faulty needle valve/diaphragm/ metering arm may be causing the issues!
