That's good to know:thumbup1: What I like about it is when your splitting large rings, instead of throwing half on the floor, the deck is large enough to put the half your not splitting to one side, if ive explained that right
I use my net bagging stand with a plank on top and stack aload of rings at waist height,,right next to the splitter, I use builders tressles to line up three bags in a row, as I sort through the arb waste, I can throw the different woods into different bags, as I leave oak much longer,etc,,when I`ve got 30 odd bags done stack em with telehandler,,,,(dont own one so whenever got a job or day on the mill rent one in)
  • Replies 36
Mine has ruptured a hydraulic pipe where it meets the top of the ram got covered in hot smelly oil not pleasant! Waiting for Riko to contact me as its only 6 months old and not done much work.
Mine did the same thing, only i couldnt be bothered to contact riko i got my engineer to do it. wish i had though as they thought it was just the pipe that ruptured but it was in fact poor welding around the bottom of the ram, grind out and re weld job.
cost a lot more than originally thought
Yeah I've been caught out before fixing what appears to be an easy fix then when it goes tits up you have to prove that it wasn't your repair at fault. I will see what they say next week.
