maybe in the states ted, but we can't use one here. A proper man basket has to be tested approved and a days training before you go in one!
Just correcting in case. Someone uses it against you.:thumbup1:
Thanks Goaty, Point taken:thumbup1:
easy-lift guy
  • Replies 42
But if you have your IPAF ticket, there's nothing to stop you using it in a MEWP
The Landscape model should work well, however if you find the need to work with a Kombi or Pas units with extensions or a power pruner I would suggest the Arborist model. The Arborist model can Handel 23-25 lbs and is convertible for less weight by removing the outside strut:thumbup1:. Just remember the Easy-Lift Harness can be safely used from the ground, a bucket or a scaffold.
The Easy-Lift Harness can not be used from a ladder!. Work smart and safe.
easy-lift guy
I recently bought the arborist model. As virtually all of it's use will be with a standard longarm set up, i was going to remove the outer ram but first tried it with both on and it balances fine.
I did try climbing steps with it but very quickly took it off.
I recently helped on a large pleached Lime hedge using it with an extended multi-tool long-arm, I recon it saved an hour or two on the job.
One thing that you can't do is walk under trees with it on.
