Youve just done aload of work on the engine havnt you?,
Had the whole front bogie and stripped the gearbox down to an empty case to replace the damaged reverse gears, also had to strip a International 574 tractor to get the gears to fit in the Bruunett box:scared1:I think you,ve seen it on one of my facebook pages?
Tcd there are grease nipples on bogies above the outer ends of the halfshafts which drops grease straight on to the geartrains in the bogies, the oil and grease must mix in the bogie casings?
Yer, I've wondered what's going on with that too. Must get that parts manual copied...
