You mean 4 times as productive till it brakes down again.... Fantastic to see the old girl going back to work again after some1 had given up on her, keep us posted.
Did an O&F and fuel filter change on mine today. There is a trick to bleeding the fuel system if need be; (don't by the way use mann filters - they didn't fit). Bleed screw on primary works a treat; secondary - slacken the top nut that sanwiches it all together and let the fuel come out the top; no need to start cracking injectors.
