need a new groundsaw again, 560xp letting me down :-/
  • Replies 415
15" 3/8 I think its a little dull as had already dropped a few and was thinking ill have to do a vid for you on the next one... Hot starting has never been a problem really unless left in the sun it goes after a few pulls but most saws are like that.
The thing is to try and re fuel it before it runs out as the auto tune will ritchen the mixture if it runs dry this can cause problems freshly fueled apparently as my dealer tells but this is the only time I use the priming bulb and it goes second third pull, but I know people my groundie included who struggle with it , but if your using it all the time you get to know its little quirks ! Hence why he gets the 357!
Yours is quieter than mine matty ! . You just needed to add a hot restart for Jon :001_smile:
I should let pete take a look!! It's loud enough though if you hear a load of saws in the woods you can tell the 560 ?
Yea you can that bud !
HI MATTY i must say you subby are right they fast saw im just worry if it goes T.TS AS THAT DOES MY HEAD IN BUT I WILL ORDER ONE VERY SOON THANKS JON :thumbup:
I've done one starter John and that's it replaced by jonsie under warenty .. I drilled it out and put a bolt through to get me by though... Any way had 266 262 ms360's 361 357 As my 60cc sawsthis is my favourite! Maybe luck though!
HI MATTYF thanks for your time on vid mate it is a fast saw yours a 15" bar yes on 3.25 chain is it a stihl chain or a husky chain thanks jon :thumbup:
