  • Replies 143
That looks good Dave! Is there still somewhere to clip a neck bungee into though? I like being able to spike up stems on removals with the bungee on and the slack just drops through. Will/can it do the same with the barrel attached! If so I need to get a barrel.
Looks cool, pretty much the same as adding a rw from what I can make out.
Looks like you'd lose the use of the top attachment so neck loops etc would have to be re-thought, but seemingly worthwhile.
Have you used it Dave?
My concern is loosing the self tending on spikes with a neck elastic. Looks like the barrel might add too much direction change to allow self tending. Could easily make an eye with the end of the barrel though..
...Have you used it Dave?
I have not. The Uni responds well to friction sharing tools and this is nice and compact. It also should be no problem to work out a way to attach a top clip-in point.
Edited by D Mc
