Hi Folks,
I have the job of re-pollarding some Lombardy poplars. They were last pollarded 10 years ago so as you can imagine, they are reaching for the clouds once more.
What is the best practice for repollarding them? Would it be to remove all skyward growth back to within 30cm of previous pruning points and reduce the scaffold to a simple trunk or would it be better to try and shape the resulting tree? Also would you remove all the growth entirely, as in below the pollard level, or would you leave it?
I know roughly what im look at doing with the trees but i am interested to hear what others do too?
James :thumbup:
Pics:
Be very wary of the anchor points, partic if they were done some time ago as appears to be the case.
BS3998, for lapsed pollards, recommends leaving stubs 3-5 times there basal diameter. A start point maybe.
Hope this helps.
Paul
Hope this helps.
Paul
Thanks everyone so far - removal is not an option if it was i wouldnt be asking :biggrin:
Paul, thanks for that, certainly a good snippet there.
And yes please Tony - what would you do?
Thanks guys :thumbup:
