skidding logs with tractor?
Ryan
  • Replies 51
Ryan
If you're going to be extracting 12,000 stems speaking from personal experience you can forget skidding, particularly without a purpose built skidder or double drum winch on forestry guarded tractor.
You start tracking back and forth over a field with a few stems making a mess then you'll soon see what I mean. And if your tractor isn't guarded you'll have branches pulling pipes off engine and poking into every nook and cranny before you know it.
Get yourself a good second hand trailer and crane (look for cracks, oil leaks, dropping, play in bushes/slew, valve block play, smoothness to work), then spend a few quid getting your current tractor guarded underneath and engine/radiator. Even if just a hobby getting decent gear will save you a huge amount of heartbreak!
Good luck
David
you ll end up using that much derv you say time isnt an issue..
it wont have to be... also artic driver will want them in a neat stack so he can grab grab fulls at a time and not strewn over 100 yards which you arent going to get skidding out.. have a go if you want and then let us know how many swear words the artic driver uses when he comes to collect. lol
sorry but get in soneone its what forestry contractors are here for
joy
Sent from my GT-I8160 using Tapatalk 2
We are winching and skidding at the moment (see pic from today) and then converting before forwarding - the ground is too side-sloped to convert in the cover and forward out. About 450 ton of it is being skidded; it's not that bad and in this job is the best solution by far. Important imo is to skid full length - not less and certainly not short pieces - the butt can dig in and the whole stick pole-vault over forwards onto the tractor! It's true that the wood gets dirtied by skidding and chain sharpening becomes twice as regular; I tried MC chain but couldn't be arsed with it in the end.
Thanks timber cutter. Thats the kind of operation im interested in. I was intending skidding in 16ft lengths as that length suits most of the timber skellys round here. As for having timber strewn over 100 yards I intend using the front loader with a grab to tidy them up. I am staring to make one like this
