angle of chain
treesap67
Makers have different angles. Think the stihl is 35 the Oregon is 30. On semi. On archer chains for full chisel is 20.....
Then there is square ground chisel round ground chisel ripping chains etc etc . Your best bet is to find out what you are using and look it up / check with your dealer but to be honest they will work good enough at 25-30 degrees
