My DIY pulley/cambium saver, made from leftovers in the kit bag.
Heres my diy cambium/pulley saver,
A mate i was climbing with had one and i had the vital parts to be able to make a retreivable saver in my kit bag so had ago and i love it,
to pull it back i just use either a spliced eye or a simple overhand knot.
consists of :
1- lyon eye to eye sling, ( could use split tail/prussik if needed to go round a larger top anchor)
2- isc karabiner
3- petzl micro pulley with matching petzl ok karabiner.
i make sure that the karabiners are facing away from the main stem
what do you guys think?
thanks
josh:001_smile:
  • Replies 20
That does look smarter then using an actual cambium saver instead of the eye to eye cord i just didnt like that the rope dosent run on the pulley alone :thumbup:
yes mate I know what your saying, but its very simple, less friction than standard cambium saver, and works well
Is it applicable from a throw line from the ground?
don't know, never tried , I normally just climb to top anchor then install it, then wizz back down on the pulley
oh definatly mate wasnt knocking your idea in the slightest hope i didnt seem like i was i used to do the same but attach a pulley to my cambium saver but i prefer the look of the eye to eye :thumbup1: just cant wait for either rope guide or pulley saver
Smart. my only worry would be that the biner may rub open while in use, only a very small possibility but a possibility all the same. swap the biner for a mallion and its sorted.
