  • Replies 61
I think it may have started life as a tanker of some description, due to the massive springs compared to my other one... It has 3 air-actuated levers on the shelf behind the seats 1 actuated the hydraulic pump.
I have an old military spec mk and we run a civvy one as a bowser. The military one was a 330 non turbo with a 4 speed gearbox and painfully slow so I have put in a 500 tl turbo engine and a 5 speed overdrive gearbox. That should liven it up a bit:thumbup1: Cab needs to go back on when the weather breaks. The pto should be ok on the chipper because it does not use the gears in it, it just runs straight through the t/c off the prop.Henry Potter is still going and he is the man for bits.
Bob
I really should bar myself from ebay....
Just took delivery of this last night.
[ATTACH]118389[/ATTACH][ATTACH]118390[/ATTACH][ATTACH]118391[/ATTACH]
God knows why, I've already got one but this seemed a bargain.
Fitted with a 3 way tipping body, 3 point linkage and pto shaft. Nice big atlas crane as well.
HI BEN hows the truck coming on then mate i seen you at show last year you told then you were on with it thanks jon
I used to work for d Collins years back and came across that wagon 2-3yrs back in a yard near Bradford. I thought it had a lot of potential and value but my bro -in-law didn't agree.
Good to know it's going to be used again
Bob
Put a 500 in mine for same reason, top speed the same ( cos of diff s I reckon) but gets there much much faster, only have to come out of 5 th if its a real monster hill! Potter s got to be knocking on now? Not been up there for 5 years or so
Sent using Arbtalk Mobile App
