Nope. Need to remove both coils then just one bolt holding it onto the crank.
Will it be obvious if somethings wrong. Or is it new flywheel? Cheers :001_smile:
Unfortunately it will be very obvious. the magnets will be in pieces and the stator/alternator will be shredded.
Good :001_smile: cant get diagnosis wrong if its like that then :lol: will come back and let you know. Cheers
Before taking it apart there is a small plug in component which can also stop it charging who h you should swap out first. I. A not remember what it's called but it has 3 wires going to it and when it's broken it won't charge, was a problem I had on my old chipper which had the same engine. I'll have a look a d try to get a picture of the same part on my stump grinder tomorrow
WM Tree Services http://www.bestkenttreesurgeons.co.uk
WM Tree Services Best Kent Tree Surgeons for Professional Tree Surgery Work in Maidstone
Thats the regulator/rectifier thing i mentioned earlier.
it converts the AC current from the alternator in the flywheel to DC and regulates the output.
You can test the output from the alternator on the wire that plugs into the regulator. If no output from alternator then take off the flywheel to check the magnets and windings.
If there is output from the alternator , but not from the regulator then replace the regulator.
same thing happened to my 27hp kohler on the Laski.Stator flew to bits distributing magnet parts thru out the engine about 3 years ago.once i got all the bits out i have just ellected to charge the battery when it needs it.
