Tree climbing spikes on the bay!
RobArb
Just reread it in disbelief, so you are up a tree standing on two of these things and hanging on with one hand I assume whilst winding in another of these tree bleeders.
But at least you have the reassurance this is "one of the best ways to climb a tree" and "No one will know you have been up" but next time "you can put them back in the same holes" even if you are 90 stones in weight!!!!! Just dont forget to only mutilate living trees as peg a dead un you will join it.
One last question how much would it cost to climb a 20 metre tree? I going to ask him now.
  • 5 weeks later...
These spikes were designed with bowhunters in mind when they set up a tree stand in order to shoot downwards and are only for entry/exit into the stand. I have a set of the "Ameristep" design which are very robust. There is a tool that fits onto a cordless power drill which is a god send. They are not designed for arborists etc but steps with straps are available which prevent damage to the tree.I normally get up 12-16ft telegraph poles and use my tree stand to take deer and pigeon depending on the lie of the land/little backstop issues. Cabelas and other outfitter supply companies over the water stock lots of different designs. The biggest downside of course is damage to the tree itself. There are other designs which basically involve screwing in an initial bolt then slipping over the step you put your boot on-the beauty of this design is that the step can be removed when not in use then reinstalled when you wish to use that tree. For an arborist to use them is a serious no no, a fall will result in disembowlment etc. Just my little input, regards...Nick Pearson, Timberline-Roe Ltd.
