  • Replies 41
check out in the Video section about wire rope cutting. I.e Chogging down.
bit of a eye opener and just imgaine with a big saw. called MS200 Cuts 10mm wire, i think.
think safe! always two ropes/attachments points a foot apart from each other.
Good points but if you're chogging down with a big saw and you catch your flipline then the outcome will be the same!:001_smile:
You'd be a long time cutting through wirecore - certainly long enough for you to notice its not wood! You wouldnt get a chance with normal rope!
Ive hit rope before and not cut all the way through, but saying that with a big saw you could go through a steel core pretty damn quick. Its no safer and gives you a false sense of security. Better off just being vigilant..
Wire cores give a false sense of security, I don't like them and if you hit it I'm pretty sure the damage done would just make the rest of it snap.
:thumbup:
If you hit wire core with a saw at full revs your going through, especially if all your weight is on it. I've given all mine away. I used them all the time when chogging down but just don't see the point if they're no safer than a normal rope. The rope is way lighter and more flexible so what's the point in the wire core unless you're flip lining up a big barrel covered in ivy or something.
Sent using Arbtalk Mobile App
  • 1 month later...
I Use a piece of 24mm Three strand with a short prussic for length adjustment, nice and stiff so flips up the trunk easily.
