  • Replies 58
Could someone on here who is using the spiderjack 2 and is now using the Zig Zag please give me a rundown on why i should give up my spiderjack for one of these. Im trying to figure out if the ZZ looks to good to be true. Thanks in advance.
Exactly the predicament I have got! As long as it self tends as good as the sj I will be getting one.
Sent using Arbtalk Mobile App
Early days and I wasn't using it in a nice broad crown where I think it will be at it's best. It doesn't self tend as well as i would have hoped. It does creep through but if your pulling yourself up your rope it will general loop down before it tends.
As said by Dexta, there is very little sit back and the best thing is the rapid descents. I've tried a spider jack a couple of times and found it tricky to control but with the zz it's ace. Playing around at the end of the day I did 30ft in two bounds. :D
So tell me, How does it work on accent? What methods are you guys using? Pulling rope through with your feet? One hand over ZZ one hand under?? Just curious before I buy one... Thanks
Ed have you tried it with a thinner rope than 13mm?
Yeah, my climbing rope is limelight which i think i quite similar to Tachyon, about 11.7mm I think.
