FS1212 is a diesel fuel filter, usually found on Cummins engines. Do you want a filter to filter diesel fuel or to filter and condition the engine coolant mixture. If the former then FS1212 if the latter talk to Fleetguard, coolant filters are prefixed WF. I used to be a Fleetguard distributer.
Coolant mix filters contain chemical packs that alter the PH of the cooling system toward Alkali. The chemical pack is different for different water capacities (as do much additive can do as much harm as to little) and for either long life antifreeze or the traditional eythelene glycol antifreeze.
A
