Turners wood wanted
Chippy
woops...realise this was turning,,not milling,,sorry nepia,,my bad,,,
You're not wrong Clive: turners' advice to me has included 'mill it, then the thick boards can be cut up for blanks'. Hence what I did to 9" robinia branches.
Jon
  • 1 month later...
always after robinia burr,,will buy any you get,,,:thumbup:
Just seen this Clive. I was gutted to have missed out on a load of robinia burrs recently near Cobham (a pair of turning vultures had 'em! :001_tt2:): the stump is nearly 6' across. I did get 2.5 pickups of free firewood from it though!
Will bear you in mind.
Jon
what sort of wood is of interest. and if i have anything will let you know is blackthorn any good. sometimes get bits 5"dia
Sorry to hi-jack the thread, but for reference, if you happen across any really large blackthorn, or any other type of plum (6" and upwards in 3' or longer lengths) please do think of me. I want to build my bedroom furniture out of it. Slackbladder and Nepia both have a bit which will go towards it, but I could do with some long bits for the wardrobe.
Re. milling short stuff. I have a really useful setup for this - running the Ripsaw mill over a single section of rail, with an end clamp. I did a few lumps of cherry for Scottie with no problems and will happily do more if it helps.
Finally, back on thread, I note you've now got some material but if short lengths of apple are any use I should have a few sitting around. They're really unsplit firewood logs, but I'm not exactly short on firewood.
Alec
  • 6 months later...
