Any ideas stihl combi wont start
sasha.p
I have a failry new stihl combi unit have only really used it a handfull of times this year and I was using it to cut a load of hawthorn earlier today and suddenly it squeeled at me and just died I have checked for the obvious to see if anything was caught up in it etc but nothing in view I tried to pull the re coil and it felt like it was pretty tight and hard to pull so popped the re coil off thats working fine it looks like it more internal I dont really want to start taking it apart as not 100 % with a combi whats what as it looks pretty tight in there and I dont want to void the warranty but am I missing somthing thats obvious?I checked the plug it looks fine what else could it be?it sounded clutch like to me I have work booked in for next week I could really do with the unit for then so if anyone has any ideas what I should be checking would be much appreciated
Ok. So you may have to take the clutch off.
Are you saying it won't pull over. Like its stuck??
You did use two mix on it?
Clutch could have broken or drive gear. Afraid taking it apart is the only way to find out. Don't get into engine until you have taken the clutch out and checked that one.
If its under warranty take it back to dealer like it is and let him check it out.
What combi is it?
Hi thanks for the replies oh no thats doesnt sound great :( its a stihl km130r 4 stroke thought it would last a whole lot longer than this .Ok have e mailed the dealer and will let them sort it otherwise my warranty may not be valid im not touching it they can sort it thanks all
