Hydraulic powerpacks / logsplitter
Wood wasp
Hello
We have a great 25t splitter powered by a Honda 6hp engine, splits anything but slow on the cycle time, as such I've been looking at getting a 15hp+ powerpack to speed up the operation.
Has anyone tried these powerpacks on splitters before and if so what was the results? There are a few jcb breaker ones on eBay though flow and pressure of current pump seems to be a detail that's not listed.
Any advice appreciated.
Cheers
D
i,ve been wondering the some thing.
the guy who does some of my repairs builds powerpacks, mostly for marine use.
i recently asked him for a quote for one to run my 15ton when my tractor is away.
he quoted 700euro for petrol or 1k for diesel. i am taking one on trial next chance i get, will
post how it runs
Before you up the flow rate make sure the pipework is man enough for the flow.
If it won’t you will get overheating in the oil which is most undesirable.
+1 and the spool block will be the bottleneck. You get more wear and tear as well as oil deterioration once the temperature gets above 40c (blood-heat).
Ok thanks for feedback, much appreciated. I'd need to adapt the hoses to connect in the powerpack so would use same ones from our cranes. Not sure what flow the spool can take but if heat issues would upgrade that also.
Are the fittings on the powerpacks for bolting on pumps pretty standard? Most pumps for this size splitter seem fairly standard fittings
Thank again
D
