Ali Nicoll discovered a very fine example of Confistulina (the anamorph stage of Fistulina hepatica) here on a veteran oak at Hampstead Heath yesterday.
The mycology department at Kew were keen to get a sample and to log the location.
Not particularly a rare occurrence (seen a few at work and elsewhere) but seemingly under reported.
ImageUploadedByArbtalk1472756761.704560.jpg.63692accfa1ec52a060004ad91553c6f.jpg.
Edited by David Humphries
Not entirely sure what you mean here Chris.
Do you mean I. hispidus having dropped to the ground from higher up the trunk?
I have seen it right at the base of trees before (mainly ash, though also on sorbi), and whilst I think it's certainly more than likely to be resi (colouration) it could be Inonotus in a more mature stage.
[ATTACH]210642[/ATTACH]
[ATTACH]210643[/ATTACH]
[ATTACH]210644[/ATTACH].
Neat! Certainly weird. The one I saw hasn't come back this year.
Must be the season, came across these in the last couple of weeks in East Sussex.
I thought I would take pics on a weekly basis to see how they develop.
This is on an apple
This on a Scots pine that failed some years ago.
This one has developed in a week and a tree I keep an eye on a weekly basis.
The Oak has basal cavities with old fungal brackets around the other side.
Still no sign of the mycorrhizal fungi coming out to play, but the last couple of days have been pretty fruitfull on the Heath of Hampstead.....
Up first a fine layering of Polyporus squamosus brackets bursting forth from above this birch canker
Meripulus giganteus erupting from the base of a number of beech trees
The spectacular Silky Rosegill (Volveriella bombycina) going through its second fruiting of the season on this turkey oak stump
and more anamorphic Confistulina fruiting beside its more usual teleomorphic version of Fistulina hepatica
(About a dozen brackets popping out from amongst these roots)
ImageUploadedByArbtalk1473277967.711692.jpg.331c46edfb8b063294622af62675ce1b.jpg.
The Volveriella looks lovely! Seeing a lot of Confistulina at the moment, including on a tree in the same location as it appeared last year; albeit much smaller, this time around. Curiously, just above (around 25cm away, and like your finds above) is a true bracket that will be able to sexually reproduce (assuming it doesn't abort). Me and Ali were discussing whether this asexual stage has something to do with the fact that the hyphae are isolated from other hyphal networks, thus making the production of spores via basidia (sexual reproduction) impossible. However, I remember reading in Mattheck's stuff that sometimes basidiospores will produce auxiliary brackets that create spores via conidia, even if from the same network of mycelium where at least two hyphal networks fused, though for exactly what reason I cannot recall. Perhaps an energy-related one, with spore birthing via basidia being more demanding.
Do you know if Confistulina can still produce chlamydospores, though? Assuming it can, then the vector of distribution would largely be that of insects.
Edited by Kveldssanger
