log burner not producing much heat?
  • Replies 69
how bigs your room and why have a flue pipe as that could cause problems my good friend had lots of trouble keeping fire going no draw etc and he found out that the flue pipe had been re used from when it had a gas fire fitted etc and all the flyash had settled in the flue pipe as it was routed from fire and then was sitting at 90 degrees in the chimney causing ash to settle in the flue liner he just ripped the liner out as the chimney was in good health ps he had a massive draw afterwards lovley warm fire now for last 2 years hope you get it sorted soon and you will good luck
Might seem a bit odd, but I presume you're not expecting to get 5kW out of a 5kW multifuel stove.
Those figures are normally based upon burning anthracite,
so burning wood would give say 2.5-3 kW?
My Aarrow stove (Stratford 90) actually says ( from memory) 30kW burning Anthracite.
Also with wood at approx. 3.5-4 kWh per kilogram,
a sustained 5kW would require you to be burning just under 2 kg per hour.
Yes you can insulate a retrofit liner. Take the bird cage off and it should be attached to the liner with a jubilee clip. Pour vermiculite down the sides making sure non goes down the liner. Keep moving the liner to get the insulation to fill the voids until you can get no more in. Replace the bird cage.
