As per Big J. The other thing I would add is, if it's a decent size with no rot and looks worth doing, dismantle it to a stick, as long as you can get and leave six inches or so on each branch stub beyond the clean stick. If at that stage the band of visible sapwood is only an inch or two thick, it should be good. Take photos of the ends and dig it rather than fell it, then paint the ends to seal. That way, if anyone does buy it they'll get the cleanest, longest butt possible, with the best chance of minimising losses through cracking.
If the sapwood band is much wider, cut clean to the top of the stick and see how much heart there really is. If it's looking much over a foot, it's probably saleable, but don't expect much more than roadside cord price unless it's a long, clean, wide butt. I'd still photograph it and then get it moved and painted. I wouldn't bother digging the stump unless it's a good proportion of heartwood.
I know people differ in view on painting ends, but I've had very good results on a walnut stump I got hold of just after an idiot farmer had chopped it off at 4ft and dug it out. I ultimately want to make a chest of drawers from it, 4ft high and the boards are 4ft0.5in long. I got it the day it was cut, painted the ends immediately and then painted the bottom end cuts once roots etc were off. I have absolutely zero cracks in it, so in this case it was worth it. Ordinary gloss paint works fine.
I wouldn't get your hopes up, but it's worth a look.
Alec
Alec
I had not heard about painting the ends.
My hopes are not high, I have a yard full of wood and try to keep the better bits to one side, it seems a shame to cut it for firewood.
I currently have approx 20/30 Holly sticks approx 30 cms dia x 3 mtr long, they are quite close to the processor but I cannot bring myself to put them through.
