anyone used one or know much about them have them in local arb shop looked a interesting saw for doing small jobs say they will cut for two hours on a charge.
any feedback would be interesting
Hi
From experience as i have cut quite a bit using these saws and have used up 4 complete chains so far.
you get approx 200 cuts of 2"-3" wood, about 40 + cuts of 5" depending on density and species.
They cut well and are easy to sharpen on the powersharp chain, you get a two year guarantee domestic and 1 yr commercial use.
I would buy a spare battery as then you have enough to finish most jobs in one go.
They are great for small jobs and small clear up, and when you want to quickly trim up, quietly.
The battery will give 1000 charges and is covered by the guarantee, it charges in just under 2 hrs and has a charge indicator built in.
These Lithium ion saws have a place in the workplace alongside your mid range petrol saw. I have used for 30+ minutes on and off on one battery charge and whilst cutting hedges.
Hope this helps, i know these facts as i sell them to your dealer
Les
Oregon Area Mgr
Hi
Les
Oregon Area Mgr
thanks for info saw one at WGM winchester looked ideal for hedgelaying as it is small and not heavy plus no fuel need just oil.
be good to take to isle of wight champs to use on hedge.
