372xp
carpenter1
just bought a 372xp,
the manual says to start the saw press the decompresion valve and cord.
the saw will not start, so i did every thing else but did not use the decompresion valve, and the saw fire on the second pull.
is this normal?
what does every on else do
thanks
The decomp is just to make it ease-yer to pull over . It vents compression until the saw fires which will automatically pop the decomp valve back out sealing the whole shooting match . You don't have to use the decomp but it saves a bit of wear on the starter pull and your arm . Go saw !
A local garden landscaper came to me with a non working 372xp that he had sitting in his shed for over 2 years, Bought it for £50! Gave the cylinder a rub down, put in a new piston and replaced the broken trigger. Fired up after a few pulls and dialled it back in.
Now my #1 saw of choice!
