Beginners climbing guide, hints, tips and general climbing techniques
I do have one issue that think I may have with it ( once it arrives). The hitch climber set up looks quite close to the bridge so I'm assuming i'll have ascend pulling on the rope above the hitch then tend the slack each time?
Or possibly moving the whole system further away, temporarily on ascent?
maybe attach my spare prussic loop with another biner to bottom biner of the HC so I can pull on the tail end of my rope instead?
That makes sence in my head haha
Yes, you're describing an o-rig.... I couldn't get on with it, even though it made my hc into a similar arrangement to my old self tending split tail set up. Have a search through the hitch climber thread, it's in there somewhere... :001_smile:
The whole lower D thing is pretty confusing, the ones on the sequioa are rated to be used while still attached by your main climbing system in a work positioning situation not for hanging in, unlike the treemotion were you can hang solely off of those lower D's not sure about the tree austria. And I know it's were your bridge is attached and it's pretty similar to being tied to your bridge but that's En ratings for you.
Sent from my GT-I9300T using Tapatalk 2
Oh ok, cheers en' !
Oh cool, would this work with the O rig? I haven't got any accessory cord, its not very long and thought the snap would make it quick for change overs... or does this need to grip the rope like a hitch?
http://www.chainsdirect.co.uk/Products/1724_0-weaver-snap-strap-hook-with-webbing-loop.aspx
Tar
That's not for life support, don't hang off that!
Best bet is order yourself up a couple of metres of hitch cord, we can never have enough cord! Cheapest solution is 1m of Marlow boa 9mm to make a prusik loop from....
