Tractor manuals with electrical daigrams!!
Hi there,
Where can i look to find a manual for my tractor including wiring diagrams? Need to get the lights working all round! Have tried looking on tractor manuals ,com but when you click on view contents page, it comes up with no electrical catagory :(
Any one helP??
Cheers Chris
auto electrition ,or just tinker till they work ,how bads the wiring
ohhhhh, i'm tinkering allright!
Peeing into the wind springs to mind lol. I do have a couple of lights working :blushing:
what are the issues / symptoms ?
old tractor, possibly wiring messed with.
Got indicators down the right hand side, fronts work when you put the power to them.....
I just really need a wiring diagram, and to see what the fuse box supplies etc, then i can go back to playing around with my power probe and multi meter...
Does this help by any chance?? I know it says another model but most are the same as they didn't really change much.
The lights will most certainly grounded to the framework. So look for damaged ground wiring. Also check the negative on battery.
Tinkering will only get you so far before you take a hammer to it. Check all frond wires are in good nick. No rust and loose. If rust clean up with wd40, run a wire straight from battery to each light. This will let you know the positive is working well.
