Squirrel Trapping
Anyone got any experience in squirrel trapping using live cage traps with a treadle? I was successful to start with, now they seem to be able to take the bait without activating the trap (so presumably without putting weight on the treadle). I place the bait beyond the treadle.
I have modified mine with some old ice cream tub plastic to stop them reaching through. Peanut butter does a good job as its sticky so harder to nick.
Also wash traps thoroughly ie no blood and wear gloves to stop your smell getting on the trap.
The other one we use is kanier or canier not sure about the spelling? They have a massive spring which chops the sq in half. They are hard to find and need to be above people's finger height so need a ladder to reset.
Try here
Squirrel Traps
Good luck
Try here
Squirrel Traps
Good luck
don't use a fenn or bodygrip traps their ok for rats but they need to go in a tunnel, but out in the open they will catch/trap/kill/maim non target species
and remember live trapped squirrels have to be dispatched
If you want to use fenn traps for squirrels, use mark 4 ones and build plywood boxes about 18 inches long with a hinged lid and hasp, cant remember the exact dimensions but make it internally just wider than the trap when set and just higher than the trap when sprung, cut a circular hole about 2 1/2 inch diameter in each end and hey presto, place on fence/hedge lines round the woodland or at the base of trees, squirrels will go in out of curiosity, trapped hundreds this way when I was keepering and doing pest control :thumbup1:
handle them with old dirty gloves and bury new traps in the ground for a few weeks does the trick
Absolute nonsense a squirrel would eat peanut butter from a human hand if you kept still long enough! I've caught 10s of thousands of squirrels in brand new traps un buried and un washed
