A question?, My best option for milling Sitka is?
Sigh,
Being resigned to being a stihl man, yes probably a 660, though I have wondered why Logosol offer the 391? is it, the farmers saw, as the basic choice or then the 660 or 880, I take this odd , though perhaps this 391 has more suitable lugging characteristics, than other more professional models from within Stihls range.
PS cheers Rob, I `am in no rush, some indication of likely price would be nice to see how it may or may not rate again the 0pposition.
Which to date would most probably be the M8 Logosol, as they have me nicely brainwashed with their regular free newsletter and promo offers:confused1:
cheers
marcus
  • Replies 23
Hi Marcus,
I'll try to find some pictures of the Swedish construction method I mentioned.
Regarding saws - if you decide to use a chainsaw mill such as the rip and flip, you could consider an 056 or an 051 as a powerhead. They're a slower chain speed, but the high torque means you can take the rakers down some and they'll pretty much keep up with a 660. My limited experience suggests that slow revving saws may mill best with skip chain - easy for the 051 as the original sprocket fitting is .404". These powerheads are much cheaper, the 051 has good parts availability (don't know for the 056 as I don't have one). Their biggest down side is that they have poorer power to weight ratio, but this doesn't matter if you're bringing logs to the mill.
Alec
Have you had a look at the Norwood Portmill? Not currently brought into the UK as the Norwood importer also is the Logosol importer and the Portamill would go head to head with the smaller Logosols.
Have spoke with Norwood and they seem happy to send individual ones over.
i liked the look of it as it seems to be easy to transport and easy to set up. Very close to placing an order as I think it could be a good first step as we get a fair bit of smaller stuff that is quite slow work with an Alaskan due to the set up for each log.
I've finally figured out the Swedish construction method I mentioned. It's called board and batten, still in use but much scaled down. The early ones have thick boards 3-4in thick x 8-12in wide.
The one I've seen close up is in Linköping which conveniently has Google streetview. I can't figure out how to extract pictures, but to find it, go to Google maps and type in:
Agatan 64, Linkoping, Sverige
This will put the marker at the junction between Agatan to the East and Apotekaregatan to the South.
Heading NW/NNW is Gråbrödragatan.
Click on the 'A' marker and click on the picture for streetview.
Head down Gråbrödragatan and you will shortly see a red-oxide painted shed on the left, and a small barn on the right.
The shed is relatively modern, with even spaced boards. If you look at the barn though you'll see the boards are random widths of between 8in and 12in.
Hope you can find it from this! If not, I'll have another go at describing the location.
Alec
Yep, that's the spot. I particularly like the front elevation of the barn. The construction technique on the older buildings is a very efficient use of timber and it really lasts well. The paint is called falun red, and it's characteristic of Sweden. It's made from tailings from a copper mine in Falun, boiled with rye flour. It is a very effective preservative for sawn timber and lasts really well (up to 15yrs). I've bought some to do my shed with!
Alec
Edited by agg221
OK
That makes sense, kinda, still need a frame behind to carry the vertical sheeting timbers, I admired this same technique in a photo in the milling section, a shed done with lovely wide oak/hardwood, looked really really well.
Being vertical the drip will get away, just need to figger some ground level detail to allow an air gap, probably sommat cunning in folded zinc sheeting
Thinking of 2nd hand galv "Z" purloins or sommat similar.
Hmmmm, could use them for my horizontal members as well, between good thick section wooden posts.
I actually like mixing materials and techniques/cross fertilization/hybrid construction on the basis that if Victorian craftsmen had had some of our genuinely good technology and hitech materials they have used it without hesitation.
Like seamless aluminium guttering.
cheers again
marcus
Yes, there's a frame, sort of. The newer ones it's a full frame, with the boards used as cladding. In the older ones the boards are structural, so the frame is simple rails fixed to the corner posts (which you can see externally) and a wallplate at the top.
Alec
  • 2 months later...
Hmmm,
I tink I have made my decision,
a 1220 Timber King, with one 7.5' extention and the 18HP Kohler, just awaiting a keen price for to incl del to NI.
Thanks Rob for your unbiased advice, and also thank you Big J.
And Agg221 also for the construction tips/suggestions.
And anyone else that knows me:laugh1: (I used to listen to Downtown radio)
Just need to find sommat affordable on tracks to extract the logs.
Mind that M B Trac on the bay with the humengous tyres would dammd near float, once the drill rig was removed.
Theres also a Mooroka tracked tractor.
