They need to hurry up and replace these ghastly engines with the 2-mix. Hopefully they will do so this year, they have already developed the FS-70 which would adapt to combi spec with a lot of hassle. So they have the engines and technology ready, it's just a case of whether they've sold the remaining stock of these unreliable 4-mix engines.
mine runs, makes a nice sound and does the job, but the top tuner on here is right :-) they got it wrong.
I am going back to the good old trusted 2 stroke asap
the sound of a well tuned and proper revving 2 stroke is music to your ears
Did you keep a note of the echo valve part number ?
Echo Part Number: 131300 56430 SUPERSEDED BY A356000031 JUST CHECKED THE VALVE IS FOR A ECHO HC1500 HEDGE TRIMMER
Edited by BILLSMOWERS
The km130 needs the timing/tappets setting and the hl100 needs a new clutch drum bearing.
If your correct then thanks very much! Andi that posted after you could his diagnosis also be correct? Many thanks :thumbup1:
