Slaice eye termination was what I was trying to spell.
Yes that would be nasty!
sent while pretending to do something important on my mobile.
Felt fine after the little play I had on your zigzag and it's so similar to my normal hitchclimbers but with less sit back. Going to try it with a sling between bottom attachment point and bridge of harness for long pull ups.
Hi Gray the zz is great...cheers Silky for the recommendation.
Gray, what type of sling between harness and zz, would be interested to know as have had a couple of long hauls recently anything to make it easier.
cheers Matty :thumbup1:
Just a normal sling like you'd use for light rigging etc, length needs to be long anough to get a good pull under the zz but short anough to reach the release toggle. Used this when I climbed on a lock jack for a while.
The best way to make those long haul ascents is a Rope Wrench above the ZZ.
Then you can do the whole job SRWP and it's less effort all round.
Sent with my iPhone from me, to you!
