Drilling through a nose sprocket?
Daniël Bos
Just wondered, what kind of bearing there is in the nose sprocket of a bar?
I've been attempting to make a mill and wondered if it would be possible to drill a single hole through the centre of the nose sprocket of a 36" stihl rollomatic to gain 2" of cut?
I've never taken a nose apart but there must be someone who has?
The rivets in the centre look like they form a circle easily big enough to make a hole for a single bolt?
Thanks, daniel.
the bearing is made up of little rollers
be warned the steel that the guidebar is made from is very hard
and will blunt a new drill bit in seconds
Sorry but that's not true - it's pretty easy drilling a bar with a good quality drill bit.
[ame=http://www.youtube.com/watch?v=eqo6tyJIUoo&list=UU9K0KfLNH84tuWi2VjlSlCg&index=4&feature=plcp]chainsawbars.co.uk - how to drill bar for Granberg auxillary oiler G801A - YouTube[/ame]
If you really need those extra 2" I'd be tempted to go for a solid nose bar and additional oiler.... I've not tried drilling through the sprocket but I'd say prob would not work and you'd damage the sprocket... could be wrong though!
:biggrin:
