Hi folks ,
i have a leaking fuel tank on our Stihl HS80 hedgecutter.
it is leaking from the rubber/ plastic part that fixes into the tank , it has a lot of play (around 2 mm )so it leaks fuel like mad. See pic below :
any suggestions on what to use to seal it ?? bit worried about using some types of sealant due to the Petrol eating it .
Thanks
Steve
Edited by ecodao
add link
sell it and get a hs81, the vibes on those things are crazy!
i have never found any thing that works really apart from new bits.
are they that bad? i have a hs80 with a 30" cut on and it gets heavy after a bit of throwing it around lol
Thanks for the replies guys, i will get a new bit on order then ,
as for its performance and weight issues, cant say i have had any problems with it.
what are the differences between it and the 81 ?? do they look the same ?? or does it look like the 85 with a curved handle ??
Thanks
steve
