Ive seen Taylor Hamels video with multi sling etc
Just wondering if anyone has any PICS of this setup for descending a pole that is to big for ropeguide.Or any other setup up would be good(no ropewrench Chat btw)
Cheers
  • Replies 26
Do you own a mechanical descender, figure eight or something similar, if so just tie an alpine butterfly, then pass the tail of your line through the eye, this then makes an SRT system on a pole, when you get to the next work station, pull on the other end of the line and the whole system pulls out and falls down
I use it with blocking down and when spiking palms, works real good
I do the same, works perfectly as long as you don't leave stubs.
Also useful on large leaning stems as you can use it to stop yourself swinging to the underside.
here are some photos to explain, first few are with a alpine butterfly with the tail pass through the eye, the last few are my hitch climber set up( I know you said no rope wrench, but it is a good investment, no need to re-set the system just attach the wrench)the rest are with a bowline and a bowline with a bright
hope it helps:thumbup1:
Cheers Ewan, was wondering where that was.
It's a good setup Atree. You can just descend on your hitch, fig 8 etc and just retrieve it by pulling on the tail without having to tie a dangling tail.
Cheers Kane
I got fig8 multi loop and sling.
Can you just back up your hitch on single line with fig 8?
Cheers onelad for your idea. :thumbup1:
