Jammys Stihl long reach hedge cutter mod
Pat Ferrett
After losing a tooth on the hedge cutter last week I rang around for a replacement head and F R Jones worked out cheapest and postage was free if I ordered from their web site.
I rang the order in at 9 yesterday morning and it arrived today at 12 :thumbup1: and to my surprise it came with a length of shaft for the combi system :confused1:, after giving it thought I remembered that I had an old hedge cutter in the container up the yard so after much digging around I found it in the corner, it was replaced when the shaft started to get hot so the question on my mind was could I make the shaft for a combi system fit directly onto the power head giving me a short reach hedge cutter and the answer worked out to be YES:thumbup:
  • Replies 21
Jammy, we did a similar thing a few weeks back. We took an old strimmer, shortened the shaft and fitted a spare hedgecutter end. Only problem is that it doesn't fold in half very well.
How did you retain the square portion on the ends of the drive shaft ?
I cut the drive shaft down to correct length and carefully ground a square end using a bench grinder. Flat file will do the job. Just copied what was already there. Works well.
